2002 C320 gearbox problems
ccd18
hey guys im new to the site just the usual never thought of a forum until i had problems...anyways im having a lot of trouble with my mums car. when u put the car in to drive it pulls for a second then stops with no drive at all. i also noticed a noise like a power steering pump running dry when i was looking at it. anyhelp would be great as its been left up to me to fix.:-(
Thanks Ciaran..
C
C180 Chris
Think your first step should be to check Autobox fluid level.
Hello and welcome, as Chris above the fluid level is the first thing to do
C
ccd18
cheers guys. do you need to buy the dip stick or is ther another way??
C
C180 Chris
Not sure about your model but mine was already in there but you need to check it with the following points observed...
Engine on and up to temp
Measure in DRIVE with parking brake ON (and i had my daughter sitting inside with foot on the footbrake as an added safety measure.)
Top up if ness with correct fluid avail from MB or Europarts (the latter about £7 p/Ltr through the dipstick tube at back of engine (your left if you are standing at front of car) near bulkhead
Don't think i have forgotten anything.........
Good luck,
C
ccd18
dip stick apart from the one working on it is missing . its replaced with a cap.
is ther any other way it can be checked?
C
C180 Chris
I think you buy them from MB if not already there, then check as above.
No other way around it otherwise you could overfill.
All the best
The 722.6 box was never supplied with a dip stick, just the cap on the filling tube, you can make one from curtain wire, and details on the forum
LYNALL
Kent
Check under the box for leaks as my wifes c320 has started to leak from the gearbox elec connector.
The dipstick or curtian wire pushs into the tube until it hits the bottom of the sump then you pull it out and measure from the bototm of the stick upwards if that makes sense!
Engine has to be running and in park when dipping.
Bottom 2 marks are cold fluid and top 2 hot fluid
Lynall
Wellington
The reason for checking in drive is so that the rotating drums do not splash fluid onto the dipstick and give a false level reading, I always set the lever in reverse, same effect but if the car runs away at least it runs away from you and not towards you.
C
ccd18
cheers guys could someone please give me the dip stick length as ther seems to be a step in the tube. one dip gives no oil the next gives way to much thanks again i really appreciate the help!!
There is a flange rolled in at the bottom of the dip stick tube, if you hit that it will show nothing, just rotate it slowly as you push it in and it will go to the bottom, no force required
C
ccd18
hey guys. Dipped the car using curtain wire and a s far as i can see its between the top two marks when its cold. it has a wizzzing noise when in park and neutral which goes away when she pulls while selecting gear. ive heard about the wee filter which is inside the box is it possible that this is blocked? any steps in the right direction would be great thanks
Ciaran..:confused:
I think that the noise is normal and no indication that the filter is blocked
C
ccd18
i dont think the noise is normal sounds like a dry power steering pump and never heard it before. mabby not a related problem thou. Have you any other suggestions Malcolm on how to diagnose what the problem could be? thanks for ure help.
What is the car please and year
I have been through all of it and nothing listed for the intermittent drive, all I can think of is the noise is from a disconnected / fractured pipe from the pump. The easiest way is to find an indie with STAR
