2003 E class self leveling suspension
Andyn666
2003 W211 E320 CDI estate
Drove 300miles to my parents last night with no problems at all. Unpacked the car and half an hour later fount the drivers rear on the bump stop. Started the car and it rose up but not to full hight.
This morning it was still at the same hight, drove my mum to work and when I stopped and got out it "self leveled" itself to the bump stop, again only on drivers side.
Drove it home, after it rose again, and jacks it up, found the front level sensor bracket has broken.
So question is does the self leveling system use the front sensor? There for meaning once that's sorted all will be well?
To stop any confusion it's just got rear air suspension not on all 4 corners.
Andy
Andyn666
Andyn666
  • #2
All sorted, for reference, it does affect the self leveling suspension, so if you have one side down to the bump stops at the back, check the front level sensor is still attached to the suspension.
Part was only £22.99 from the dealer and they had it in stock. Easy to fit, wheel off then take two nuts off and put the new arm on.
Andyn666
Andyn666
recently fixed there very same thing on a customers E , I just free'd the arm off and tack welded it back on
I thought about welding it but for the price I figure I might as well replace it
Andyn666
Andyn666
Well it's back on its bump stop so it looks like it needs a new bag.
