2003 Sl55 AMG transmission slack & squeak??
NickH72
Hi all,
Not sure if thats the best description so i will explain.
I have a late 2003 SL55 amg with 35k miles
When i pull away there seems to be some "take up" in the drivetrain after the initial pull away and i can hear a squeak when it does fully take up.
If i pull up slowly then pull away slowly it doesnt do it.. if i hit the brakes then the throttle it is quite obvious in a little delay or jolt and a squeek.
Any ideas? to me there is some play somewhere or something is shifting back and forward on a mounting..
Appreciate your thoughts as its really getting annoying!
Nick
N
NickH72
  • #2
Although convinced its a transmission squeak i have just read a thread about the supercharger belt squeaking in a similar way.. so still open to suggestions but maybe i am looking in the wrong place? does seem to feel like "taking up the slack though"
Hello and welcome, I run a 230 500SL and what you describes seem to me a drive train fault, thought its hard to think of what it could be, there is nothing known,,I would get an indie to check the prop shaft and axle drive shafts.
www.ckinsurance.co.uk
