Hi all,
I bought a 2006 plate GL420 last year and on the way home a coolant warning came up on the dashboard.
I thought it was due to the car not having been driven much so topped it up again and thought that'd be the end of it. But it keeps happening.
It's been to various garages, had a new header tank fitted, 2 new header tank caps, a new water pump as well as going back to the dealer who I bought it from to have the attached part changed - what is this and where does it sit?
It came back but in the same way as before, the top up coolant light came on again on the way home. I was told that as the engine has run, this was expected, so I topped it up again.
The dealer I bought it from is washing his hands of the whole thing and has refused t help any further.
Unfortunately, it keeps happening though. If I drive a few miles, the top up coolant light comes on?
There are no visible water leaks, 4 garages have pressure tested it and they have all said that there is no problem with this.
Mercedes diagnosed a faulty engine and said it needed a new one.
From my own findings;
1. It happens when the car reaches 80C.
2. The car doesn't over heat though, the temperature of the engine stays between 80C - 90C.
3. I've checked and the fan seems to work - the one at the front of the engine bay, used to cool the radiator, although I can't see if any of the blades are broken as there is very little space.
4. The water seems to be leaking from the outlet on the header tank.
Has anyone seen this before and could anyone please help?
