I have a dashboard warning about this, have just pulled the bulb holder expecting to find a blown bulb and found this instead. I have a horrible feeling fixing this could be costly!
Thanks Alex, I've replied to your PM, access is crap, in the photo I've got the part pulled as far out as the wiring will allow, holding it with a pair of thin long nose pliers. I've not tried to pull the silver bit over the bulb, but even if it could be freed I'm not certain there's enough access to allow the silver bit to be accurately and strongly glued back into place - unless removing the cover above gives enough access and visibility! Beyond anything I'm prepared to try, that's for sure. Only thing I wonder is if all 3 bolts that hold the headlight unit are accessible without removing the bumper - OK, one will require removing the wheel and half the screws holding the wheel arch liner, but the other 2 may be accessible by removing the covers along the front top. We'll see when I bring the car to you!
AIB understand your special Mercedes deserves a special insurance policy. We have a refreshing attitude to insuring high performance, modified, imported or classic and vintage cars and deal with the UK’s leading insurers. We offer discounts for length of ownership, where the vehicle is kept overnight and limiting the mileage and can also cater for those clients who need higher mileage and business use.
To obtain a quotation please call the team on 02380 268351 or visit us atAIB Insurance
