When stuck in traffic yesterday I went to drive off and very little power no kick down on gearbox pulled over restarted power back same again next hold up cleared after restart
Mine did this had issues from cold its was an o2 sensor buggered, the difference between temps on start up was too great and went into limp mode. After the initial start and a off and back on the car was fine. Only way to tell is to take blobcats and Alex's advice star is the answer. It could be a whole host of things
As above - could be many thinks either in engine or gearbox.
Getting codes read on Star is the cheapest way to get to the bottom of it. A generic code reader will not give all codes.
