2009 CLS Grand Edition Limp mode when warm
dan90210
CLS 350 Grand Edition
So as per title
From a cold start up the car runs absolutely fine and will continue to run fine for endless miles until the ignition is switch off.
When the car is restarted it'll only drive I'm what feels like limp mode, max revs 1500 rpm and no or little accelerator.
When the car is turned off and allowed to cool it's fine again.
Any ideas on where to start looking?
I've had a previous fault code showing the O2 sensor which I drove on for a while but that's been changed now for a new one and the code for that hasn't returned.
So from cold it'll drive faultless for at least 200 miles as I've done that. As soon as I shut it off and restart max 1500 rpm until it cools down again!
Scratching my head with this one!
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
First off you need to get the codes read.
  • Like
Reactions: DSK
So as per title
The O2 sensor doesn’t cause limp mode .
If you are handy , you can remove and clean the actuator with electrical spray cleaner and put some high temp grease on the worm gear . Check that the metal wires that leave the outside of the pcb board haven’t broken .
Remove the exhaust back pressure sensor and spray clean the hole on the underside to get the black gunk out .
Try a 4.7k ohm resistor (£1) plugged into the middle 2 contacts on the electrical supply to the swirl flap motor which is under the black bat wing .
Remove and spray clean the egr .
These all share the same fuse in the engine bay box on the om642 . 15amp on my w211 …might be F44 on mine ?
These are all free jobs that may well address some of the limp mode om642 issues .
D
dan90210
Hi.
No stored codes.
Previous O2 sensor code but that's been replaced and no further codes
  • Like
Reactions: DSK
D
dan90210
Which actuator are you describing?
The black box on the side of the turbo .
D
dan90210
Is this the diesel ? If it’s not ignore every have ever said .
Yes 3.0 diesel.
I'll give those a go.
I did wonder about the turbo actuator myself.
Just seems weird that everything is fine until a hot restart. I'm thinking something isn't returning to its expected position at ignition off
Yes 3.0 diesel.
Just seems weird that everything is fine until a hot restart. I'm thinking something isn't returning to its expect position at ignition off
Someone might be able to advise if the crankshaft position sensor on the side of the engine might behave a bit like this ??
D
dan90210
I've noticed that "Calculated LOAD value" on my scan tool is 0.0% when cold and anything up to 30% when the engine is warm with ignition on and engine off.
Is that a clue?
Is that a clue?
That’s way above my pay grade buddy :)
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
If it's going limp ,codes must be there , Shirley??
Afaik a poor crank sensor causes , hard starts not limp mode.
D
dan90210
D
dan90210
Nope no Dash light lit and no stored codes at all.... Well "yet" anyway. Been going on for a couple of weeks now so I'd have expected a code by now.
I was hoping the new O2 sensor would have fixed since that was the only code showing on the scan tool.
That's been replaced, codes erased, and no further codes present
onefortheroad
uk.
Eml comes on after 6 or 7 consecutive same faults .
O2 sensor as mentioned won't cause limp mode.
don't rule out the transmission if it's an automatic.
If you've 2 keys , try the other . Long shot but can cause issues .
D
dan90210
So it's in limp mode again so been out to check the position of the variable vane arm on the turbo, that matches the position for when it's working.
Same with the throttle plate after the MAF sensor, it's in the same position as before ie at 90° to the intake.
That's not to say they aren't faulty but they "look" OK and have returned to their ignition on engine off position nicely.
Still no codes.
You mentioned gearbox. Yes it's an auto box. What can I check there?
D
dan90210
  • #17
And in a few hours it'll all be back to normal again!
KennyN
Paisley
BMW 440i, Cayenne, ZX12r / ZRX11 / ZRX Monoshock
What code reader are you using ?
Maybe worth paying for a scan at a MB Indy`s who will have access to the factory level of diagnostics.
K
onefortheroad
uk.
So your saying from a cold start , fuel permitting,you could drive for hours, upto 90 degrees , until it would run out of fuel. ??
Turn it off when hot and you go limp ?
