200E 1993 Paint faded
curley
Hi All
I have a spare car I like to do some work on when time allows.
I have a very standard 200E Petrol and have almost everything working
as it has very little electrics,no sunroof or Elc windows ,a lot less to go wrong someone once said !!!
The car has the old non metallic paint red/maroon and it has a very poor
quality it looks great when Wet !!!
I tried TCutting with a hell of a lot of elbow grease and it improved but not
good now , any suggestions other than a full respray in metallic :p
Xtractorfan
S class
You need something a bit stronger than T-cut to remove the whitish scum on the paintwork, try mixing some compound ( G3, G6, or even G7) with the T-cut.. G7 contains ammonia and needs to be taken off fairly quick, but it cuts better.. next stage is T cut on its own or you can use it mixed with some paraffin / heating oil for an enhanced shine, finally finish with a good quality carnauba wax..
Also check out one of the Detailing World Forums for some polishing tips
You could also try Color Magic (red) after the T cutinng
Xtractorfan
S class
Never recommend the use of a mop to anyone who has never used one, they will always do more damage than good..........and end up needing a repaint
C
curley
Thanks for that I have been to a Motor factors and got as shock when I was
quoted 60 Euro for a Ltr I think was in the plastic bottle G6.Surely I can do better than that.and how much will I need to do the car any ideas.
Red is the weakest colour in the spectrum, it will even change colour under the top clear coat, this is further aggravated by the heat under the bonnet making the colour change
Xtractorfan
S class
60 euro for a litre of G6.... Its around £20 per Lt. for farecla..one of the best polishes out there.. Where are you..Ireland I reckon... You surely must know someone who is heading up north and will get it for you at a keen price,,
C
curley
Thanks for that I went up North last month and was to focused on stocking up
the wine cellar!!!,but I will be checking where I can purchase before my next trip.
C
curley
Thanks Malcolm,
That reminds me I need to renew the bonnet padding what do you recommend
it has completely disintegrated from both cars
Thanks Malcolm,
The OE parts cost £80 each,,if you are nor worried about keep it original you can do much better with an after market sound deadening dense foam, and self adhesive too fro a fraction of the price
