2010 CLC 200 KOMP. Rear Brake Pad Specification
Ant747
Cornwall
Clc 200 Kompressor 2010
Hi to all. Does anyone know which rear brake pads would fit the above? It seems there are two types available under the registration of my car on Auto parts sites. One seems to facilitate a wear indicator and one not. Does anyone know if the above model has a wear indicator? Thanks a lot. Ant.
Well , I don’t think my CLK rears have a wear indicator (I cleaned the pads up a couple of weeks ago .
Either look through the wheel gaps for wires on the back of the pads calipers , (one side may have a wear indicator ).
Or order both sets and return the unused ones .
I’d phone up MB Grangemouth and get the info (and probably the parts) from them
daibevan
Alltwen, Pontardawe
W203 C200 Kompressor Elegance SE 2006 Tanzanite Blue with cream interior
The ones for indicators just have a hole drilled towards the end of the pad. I think you could use these even if you didn't have the sensor to slot in the hole.
Or just have a look.
A
Ant747
Cornwall
Hi and thanks - my car is a CLC but what you say makes sense. Thanks again.
A
Ant747
Cornwall
that makes good sense also thanks
