2012 Sprinter 315CDI indicator lamp not blown but stopped working. Is there a fuse possibly for LHS.
Rob Fowler
2001 ML 320 and 2012 Sprinter 315CDI
On Sunday suddenly my LHS indicator lamp stopped working. Right turn indicator is fine. Thought it was a bulb but the bulb is fine. Where else should I look to solve the problem? Many thanks. RF
R
Rob Fowler
  • #2
It turned out to be that the main connector at the light cluster had corroded slightly and wasn't making proper contact. This even after ihI had connected and disconnected the multiplug a few times. ThewThe special contact spray fortunately solved the problem. All good now.
This is a common problem. In some cases the bad connection can cause the connector to overheat and partially melt.
Keep an eye on it and make sure both sides are always clean and dry.
R
Rob Fowler
Many thanks LostKiwi. Will do. Eish!!
