2015 SL400 FUSE BOX ALLOCATION
Tim Stacy
2015 SL400
NEED HELP FINDING FUSE BOX LOCATIONS AND THE IDENTIFICATION AND TRYING TO FIND FUSE TO CHECK MY FUEL GUAGE. FULL OF GAS BUT SHOWING HALF TANK AND THE TRIP TAB ON DASH WILL NOT PULL UP
John Laidlaw
Wirral
Land Rover Discovery 4
Welcome, sorry I have a fuse chart from the R230 but you have the R231, hopefully someone will be along soon with it...unless they are the same in which case ...
T
Tim Stacy
2015 SL400
Thanks and I will check. On the instrument cluster if you were to select trip it does nothing like miles traveled miles per gallon miles traveled and I’m thinking it is tied with gas hand not working?
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
Do you not have the fuse chart and fuse box locations on a paper tucked away in the tool kit.?
Thats where I found mine.
T
Tim Stacy
2015 SL400
Unfortunately there’s not a tool kit. Just first aid kits and lug nuts. Thanks
John Laidlaw
Wirral
Sometimes the fuse chart is stuffed into the fuse box on the side of the dash too, worth a look
Edit : apologies I meant to put in the cubbies behind the seats, not on the side dash
AMGeed
Poole, Dorset
Strange. Do you have a collapsible spare or a tin of gunk to seal a puncture? No air compressor to blow up the tyre?
I think somebody took out the toolkit before you took ownership of the car. There should be a wheelbrace, air compressor, a jack, and a wheel mounting bolt.
Edit.......... Found a fuse box PDF for your SL that you can save or print.
  • 14 SL Fuse Chart.pdf
AMGeed
Poole, Dorset
Unfortunately the last person to look at it kept it!
Click on the PDF in Post#8 and save it if you need the fuse box and fuse locations for the R231 SL.
