220 CDI Engine Temeprature
golfman
Could you please help me. My 220 CDI was running at a low temp 60 - 70 deg, so I changed the thermostat. I thought this fixed the problem, the temp came up to 80 deg, heater works fine and no strange noises. However I am now paranoid about engine temperature and notice it rise to 90 as soon as the the engine is put under the slightest load, is this normal?
My memory was the car would run at 80 except in arduous conditions of high external temp and load.
Please relieve me of my paranoia of temperature and dreaded air locks.
If it is air locked, how do you remove it?
padrig
j26 m62
220cdi high temp
hi
ref airlock, as far as i am aware these engines don't have a problem with airlocks, but if you run your engine on tickover and put your heater on the hot setting and remove the header cap this should expel any air in the system.
Also squeezing the fat bottom hose with the cap off will remove any air
G
golfman
Thanks for the rapid responses, do I take it you think 90 deg is a little high for an engine under minor load?
Engines are at their best at over 100c, do you have a faulty sender for the temp,,that could give a rapid change on the gauge
G
golfman
The temperature sender is a new one which came with the thermostst housing, genuine MB.
It would be interesting (to some) to see the variations in temperatures these engines run run at after say 15 miles.
220 CDI owners please post you readings.
Blakey
Brighton UK
70 - 90 depending on whether I drive slow or fast.
Heater never gets super hot either - duovalve?!?
Rory
Cheshire, UK
I have a C270CDi and can't remember it ever (once warmed up, obviously) being anything other than approx 85C.
ricaT5
Hi all, further to this thread i run a c270cdi and in the recent cold weather the heater doesn't get warm and the dash screen shows its running at about 50 degrees even though the gauge goes up to about 120. A quick call to a MB garage in leeds for a price of a new thermostat I was told that it is very un-likely that its the thermostat, had it been an Audi or any other car this would be true but not for a MB! I'm a little confused. Any ides anyone?
rapide
west sussex
1997 E230 (no rust) 2016 volvo xc60 r/design. se. lux. nav.
temp on mine creeps up slightly if running climate hard on cooling interior down due to excess heat in condenser which is in front of rad! always been the same .
steviewestlea
I posted an earlier heater problem with my C270 CDI 52 plate. My heater is only lukewarm. Engine takes 4-5 miles to get warmed up, then it sits at between 60-70, even on motorway. I've resorted to blanking off part of the radiator after some advice on the forum. It's marginally better, now 70 constant but even in traffic it never gets above 80.
Regards
Steve
higgy1961
hi
fitted new thermostat on my 2000 e220 cdi today,it used to sit on 60 degrees,now it is 80 to 90,the heater is now really good and you can barely hold your hand on the vent when on the hottest setting.car runs a lot better as well.it took about an hour and was,nt too bad a job.i found it easier when i removed the oil filter,its gives you lots more room to work,just make sure you put somes rags in the filter housing so you dont drop the bolts in there.
gibsones135
North Cornwall
GLA 250 4MATIC 2014
Sits at just over 80 around town or quicker road...takes about 5-10 mins to get there at low speed though.
pre_1970
Herefordshire
W203, 2003 220 cdi
this is my job for the weekend, ive bought the thermostat, but not got any coolant. can i get from anywhere or is it main dealer only?
