I recently changed the oil in my E300 TD, W210 estate, prior to a long trip around Europe. Previously I had a multigrade, and changed to a fully synth MB229.3 rated oil. The car has done less than 100K miles, and I consider it in very good condition, with no oil consumption, no smoke etc.
During this trip I have noticed a new oil leak from the engine area, and have had the oil level warning message several times. I am topping up at more than 1l per 100km. After removing the cover panels under the engine and having a good look round with a torch the source appears to the LHS of the block, somewhere in the area beneath the inlet manifold towards the rear. The starter motor is wet from oil, but it is hard to determine if this is the primary area, or just oil being blown around. The cover panels are soaked with oil.
Rocker cover seal is dry, oil cooler hoses are dry (but cannot really see the unions), starter motor is wet, joint between engine and bell-housing is wet, steering rack is wet, but probably due to drips from above.
Any have any idea what the source might be, or next steps to diagnose? Any common leak problems on the 300TD? I still have 3000km to cover before getting home, and would like to know the source rather than find out on the hard shoulder!
Thanks for all input, Andy.
