dr-photo
- Jun 17, 2009
- Location
- france
- 308D sprinter, citroen berlingo
I have just bought a 1997 308D flatbed tipper. It needs a fair bit of TLC, but I have noticed that the rear wheels look abit on the bonk. Looking closer I have noticed that the anti roll bar connection on the axle to the chassis has a right angle on the one side, whilst the other is way off a right angle. The axle looks like it has been touching the exhaust when under large loads. This makes me think that the axle has moved forward on the leaf spring on one side. There don't seem to be any marks on the leaf to guide me where it should be. Moving the axle back along the spring looks like it would solve the problem, but it would also elongate the rear drive shaft along the splines( if it has splines that is?) the drive shaft joint looks quite compressed at the moment. Does anyone know how long the splines are? Would moving the axle about 2 centimetres along the one leaf have catastrophic results, it would square everything up, and looks like the easiest diy job to do. Also does anyone know the torque settings for the axle to leaf spring brackets bolts?
It is a sprinter 308D. I am in france so the model/engine combination may seem strange.
Many thanks in advance.
