313cdi Sprintshift problem?? anyone know anything about this??
marknewmanuk
New Registration
Hi all, I wonder if anyone can shed any light on this one
i have a sprinter 313 cdi 2001 sprintshift
it sometimes takes a while to engage A from N, often when cold, it has today become almost undrivable
when you select A, it will mostly pull away, 1st and 2nd, when it reaches 3rd it will start to slow down, rpm's drop and keep trying to change gear, if on a flat road it will drop down to 4th and continue, if you force it by shifting by hand,
reverse works 100% and is ok, (apart from cold slow select)
Anyone know anything about this,
regards mark (bristol)
ELGRINGO
fylde coast
e230 c180 sl280 brabus a190 smar cart
Hi mate could be a pump pressure fault just replaced pressure accumalator and relay, for a fault like yours. If you use star machine can check pressure in actuall values. if not correct check for leaks, possible pump, accumilator, relay fault hope this helps regards.
mani2007
New Registration
london
mercedes sprinter 411 cdi
mercedes bens sprint shift gear box problem
Hello mate,
I have mercedes sprinter lwb 411cdi and recently it has started to give me the same problem as you have stated .. I wil really appreciate if you can tell me what was wronge with your van and how did you got it fixed?
Regards
Usman
