320 cdi, auto box won't change
rpe2
Silchester
Right, you have the 722.6 box.
My money would still be on the speed sensor in the box. The gearbox does not have to be removed, but the sump/ valve body does.
Parts are about £140 + oil.
Taking to a merc specialist will determine whether this is the fault, buying a code reader from ebay may tell you the answer, but for simplicity, go to an indie, not a job I'd like to undertake without the use of a ramp.
Olly @ PCS in Southsea comes highly recommended, (the nearest one to you I can think of), or Colin + Dave at MBS in Southampton.
I agree with Richards post above,its spot on:D
Callrova 4x4
Sussex
www.callrova.com
Range rovers
Thanks Guy's,
That's excellent info.
I will attempt it myself, I have ramps in my workshop.
Only thing i dont have is the diagnostics for MB. I have approx £40k worth of diagnostics for land rovers & range rovers right up to 2009.
Black C55,
If i get myself into difficulties, I will contact you.
Thanks for all your knowledge guy's.
Callrova 4x4
Sussex
www.callrova.com
Range rovers
Right chaps,
I've got the sump & solinoid block out. No it's just nicw & shiny underneath the gearbox.
One question guy's, Is the part i need to replace attached to the solinoid block, ie: the black plastic housing housing the electric socket etc?
rpe2
Silchester
When you put it back together, keep a close eye on the elecrtical connector that you have unplugged on the outside of the box. You may want to get a new seal as this is a weakspot on this box, and can leak if disturbed (as you have done).
Callrova 4x4
Sussex
www.callrova.com
Range rovers
Got it all back together, including the plug/socket.
Now, do i need to clear the ecu as the gearbox is still in limp mode?
Xtractorfan
S class
Yes the car now needs to be starred, and you will be amazed at how smooth the box is
