320 CDI Engine Probs
ajlsl600
france
Dealers are doing shed loads of them, no patten, 10.000 miles or 50.000 miles, they just start knocking!!
Do these have stop start? Is oil feed thru centre bearing ? Maybe front main last to see oil and many using thinnest oil grade ?
Doug1234
Bedfordshire uk
1997 w210 e300td
When I change the oil on mine I put half of the oil in through the filler cap and the other half goes in the oil filter casing , this is recommended on Jeep forum to do it this way.
That’s what I do with my om642 engine as well
Terrykal
Hertfordshire
C219 cls55 amg
Didn't know that.
What reason would be to suggest pouring 4litres from the filler and other 4litres through filter housing?
I can understand to suggest for example 1lt through filter housing but half the quantity?
Please advise
Doug1234
Bedfordshire uk
1997 w210 e300td
The oil filter canister /mount is at the top of the engine , therefore there is minimal oil pressure until the filter is full.
Here is a thread from a Jeep forum , bit of an argument going on during it but about half way through the reason for filling this way is explained.
You mention 4 litres x2 so your engine only uses 8 total ? , 642 in my Jeep takes 9.5 and Jeep now recommend to use 5/40 instead of the recommended 5/30
Terrykal
Hertfordshire
C219 cls55 amg
Thank you I will have a look into the link.
If not mistaken, oil pan has 8.5lt capacity and this is the recommended amount. At least in the w211/s211 with the om642.
I should have written before 4.5 and 4.0, my mistake.
Didn't know that.
Please advise
I heard one of the Indy’s mention it a few years ago , not sure of the exact reason
www.W140.co.uk&www.r129.co
