320 CLK Power Loss above 4000rpm
Status
Not open for further replies.
beano
New Registration
Is there anyone out there who can help?
The car is giving me grief above 4000rpm. If I floor it the car pulls to 4000rpm no problem, but above that it doesn't pull so well. It will splutter a little and then kick in. If I put the car in "park" and rev it up it's Ok to 4000rpm and then seems to splutter a bit.
Cheers for any help in advance.
Beano
Arnie
London
When not in gear (P or N), the engine revs (on this 6-cyl, 320 engine) are purposely limited to 4000 rpm so as not to damage the gearbox.
If you still hit this limit when driving in gear, you may have a fault/bug with the ECU. Perhaps it's not sensing that the car is in gear, but since this is all done through a CAN-bus network between engine and gearbox (and brakes) it will require the proper diagnostic tools. It's no longer like the old-days with limit switches and mechanical linkages. Digital information now moves around between the controllers in each unit at 500Mbits/sec.
Perhaps just a reprogramming of the ECU will do it, but best to have the system checked and fault-codes, if any, read, in case some sensor or other component is faulty. Not really a DIY job unless you have the diagnostic tools.
Finally, it was suggested in another recent post that the W/S switch on the gearbox, when in "W" mode, also limits engine revs (apart from making the gearbox start in second gear). Try to see what gear the car starts-off in. Possibly you just have a faulty W/S switch. (??)
Robert Thorne
Could be the O2 sensor on the exhaust system, I had a similar problem and thats what cured it approx. £200 :D
Status
