380 Aircon compressor removal
C
corvus
Hi all,
We've entered the plymouth-banjul challenge and will not be needing the aircon.
If I remove the compressor will there be any oil leakage or is it just bolted onto the engines outer case?
Richard Moakes
Newton Abbot, Devon, UK
CL500; ML500
You would need a different length drivebelt, probably worth measuring the length without the aircon compressor with a piece of string to help you size the replacement.
Good Luck,
Richard
C
corvus
Thanks for the info Nicky / Richard.
I'll take it off this week and chuck it on ebay - money will go towards Cancer Research UK.
Regards
Time for a silly question, but there's no chance that would fit my 1991 300Se would it?
C
corvus
I don't know what the repercussions are of removing pipes etc...
C
corvus
We'll I took the belt off and left it at that so that the new owner can use it - if they can get it charged in the gambia!
flagstaff
York
'94 E220 Cab
excuse my cynicism, but: should you be attemptng such a perilous quest with such scant knowledge? ;-)
