450SL Engine Knock
TBS
SC
I recently drove my recently acquired 1976 450SL at 80MPH for approx 75 miles on the Interstate and ran fine. Upon exiting the Interstate I noticed a very noticable engine knock and am presently trying to diagnose it. Because it came on suddenly and has continued without increase or decrease I question that it is a Rod. Could be. Thinking more a collapsed lifter but cannot find such upon valve cover removal & inspection. Would anyone have some suggestion?
Con rods give a definate knock where as a lifter is more a tap, normally with a big end the oil presure will be low. Little ends a more of a tap noise and have no effect on the oil presure.
A skilled mechanic would know if it was a big end instanly, you cant mistake that sound.
Malcolm
T
TBS
SC
please explain "big end"/"little end"
T
TBS
SC
In your opinion can a rod bearing be removed/repaired/replaced whith engine in car?
If you can get the sump off,then yes the big end bearing can be replaced in the car, if it is Big end gone replace all of them.
malcolm
eric242340
Banned
China
Its quite a difficult to do the big end (on this model) in situe. Plus you will need to measure the crankshft. If the crankshaft is out of round or badly worn you will have to have it re-ground and fit oversize shells. Should this be the case you will have to take the engine out.
T
TBS
SC
reply
Thanks for the info. This being my 1st MB I am beginning to realize there is much more to this car than many others. I hope I won't have to pull the engine. Thanks again for the help.
