450SL Oil Cooler Help please
Isdyl
Hi - Please could someone advise me on how to remove my leaky oil cooler? It is attached to the off-side of the radiator & I can't get it off!
I have removed the two oil hoses top & bottom, removed the two bolts top and bottom attaching it to the radiator, and released the clip at the top, and expected it to slide upwards. It still seems attached somewhere - can anyone suggest where please?
guydewdney
Tring, Herts
www.atct.co.uk
if its the same principle as the others of the era - then it might have two mre hidden bolts at the front- you have to remove the whole radiator/oil cooler - THEN undo the bolts...
or its just stiff :)
I
Isdyl
Thanks - I was worried I may have to remove the whole lot. I've already sheared the thread off the top hose connector! In fact, every bolt has been seized & needed drilling out.
