51 plate c200 kompressor coupe episode II
jungleboy
Hello very helpful people of mbo
I posted previously regarding my alternator / under voltage / defective consumer notices and decided to grow a pair and take the alternator out myself (after having checked the battery etc)
Its a bosch alternator (where the chat about that haynes manual ???) and the first thing i notice when removing the regulator/brush holder is a distinct step where the brushes hit the slip ring , the second thing i notice is that one brush is shorter than the other.
The cars done 92k and this is clearly the original alt
Was clearly hoping for something more definative at this stage , i suppose it could still be the regulator......
I did have a good picture of the wear on the slip rings but my bluetooth has packed up , one of those days
Many thanks in adavnce
JD
hello mr jungle massive,
i am not at all sure what your question is, but those brushes look all fine and dandy. if the tips are not pitted, oxidised or dull looking then look elsewhere.
remind us, what was your problem, does the battery actually go flat? does the charging fail at certain rpm?
a joke. Q. why was the mouse scared of the jungle?
A. because the junglist massive!
The brushes look fine to me also, the regulator could be at fault... If I remember correctly you were getting under voltage warnings
J
jungleboy
Gentlemen,
I got the undervoltage alarm then the red "go to workshop now!" alarm then she died after having done about 25 miles (trying to get home to the garage!)
I chraged the battery a bit and measured the voltage when it was running and saw that i was steadily falling away
My mechanic pal used a fancy battery tester and proved it was nt at fault so as i saw it , the only culprit could be the alternator
I was hoping that the step created by wear on the slip rings could be the problem , but like you i can t see a problem with the brushes
I ve not seen many people on the forum with failed regulators but I suppose that could be the problem, hope so , I can afford one of those ….
I presume you can hook up a vaiable power supply and check that the output voltage is uniform ? Has anyone doen this?
Thanks Lads
i must point out that on your car the charging is determined to some extent by the front sam. for sure your alternator has the brushes, regulator and rectifier, but the sam has final say on whether it charges or not.
J
jungleboy
excuse my ignorance , whats a sam?
:Oops:
A SAM is a signal acquisition module that takes in info from all of the electronic in the car,,it runs using the CAN bus,, that is a high speed date system going around in the car
