722.6 (C250 CDI) blowing ATF from breather...
moj91
Northamptonshire
W213 E400d-T, W204 C250CDI-T, W220 S320CDI (AMG Kit), W168 A170CDI, W210&W124 OM606...
Hi All,
Had a happy gearbox, now its unhappy...
Working just fine, 115k miles..
Had the gearbox oil/filter/plug changed by a good indie (as advised by an autobox specialist a while back, (preventative maintenance)).
Drove to Cornwall for a week break, no issues, excellent changes etc.
On the way back noticed a little dampness on the undertray... not sure why looked under the car but i did, didnt think much to it.
Following day, noticeable smoke (ATF getting onto exhaust) and pretty significant leak.
Checked level with dipstick, just above the bottom cold so added 100ml increments until back into correct range and drove maybe 10 miles gently to garage. All changes etc still perfect.
Garage checked plug o ring again as we thought that was the leak, turns out not, its blowing fluid out of the breather on top of the box, and pretty significantly now.
Id be quite surprised and disappointed if the gearbox has suffered a major failure internally, its been looked after, and only on 115k miles. ATF was previously changed at around 40k miles as was the consensus to do at the time.
Our other cars with 722.6 box are all over 200k without issue, bar one which had a TC fail at 220k ish, and had not had any oil changes.
Anyone know what could be going on?
Thank you!
Jim2
Sometimes..they can do that if they are overfilled.. but I'd always check mine when the box is at 80c..I never do it when cold. So as a first reaction, that's what I would do, if only to eliminate the oil level as the cause. After you cleaned it up etc. did you notice if it did it again, or has it been Ok since?
umblecumbuz
Wales and Gozo
Sounds like an overfilled box. Does the Indie realize that you fill the box while the engine is running with the selector in Park, and the box at operating temperature?
If the box was filled with the engine stopped, then it would be very much overfilled even though the dipstick will show the correct level.
Yes, the only reason they blow out the top is from being overfilled. Engine running and in park as above.
moj91
moj91
Northamptonshire
Well this is the thing, it did possibly 700 miles before it started blowing the ATF out after the oil change.
Both the indie and I have checked the levels with various correct dipsticks at cold and up to temperature, with the 'starting' levels correct it is till spewing out, yet the gearbox is operating otherwise normally.
The oil expands significantly when warm, @70Deg. I would still suggest that the box is overfilled. Are you checking it with the correct dipstict?
I only check it at 70Deg.
moj91
moj91
Northamptonshire
We've been using the lazer dipstick set, with the correct dipstick as per their guide. The biggest alarm bell, i suppose, is that the car did maybe 700 miles before the ATF started noticeably spewing out/burning off the hot exhaust and smoking, but is still changing/engaging/accelerating smoothly. If it was overfilled from the initial oil change I would have expected it to spill out on the 30 mile drive home from the garage.
I/we rechecked the level with the Lazer dipstick, inserted to the correct depth (also using another car, same gbox as reference, which showed correct levels at the depth inserted both cold and to temp) whilst the box was up to temp, and running in Park. Level by this point had again dropped to the bottom of the dipstick, so 100ml increments were added to bring the level up to the correct 80c marks, still whilst running in so that the added oil could warm up and expand. This just resulted in the added fluid being blown out again over a short drive. Having changed a 722.6 gearbox oil myself before, and being assured by the indie they had done countless ones in the past (I have no reason to distrust the indie in question) I am still hoping that it is somehow overfilled (hence it is still operating correctly) but I think we would have ascertained this by now - I fear an internal issue, hopefully not with the gearset, but maybe with the valves/valve body/my knowledge therein of these gearboxes thin on the ground haha! Maybe the float has jammed open? Who knows at this point.
We will see, the car is still with the indie. I'll report back with the diagnostic/resolution once we have it, even if it is a 'tail between legs' answer... Any further input is certainly welcomed!
umblecumbuz
Wales and Gozo
Even after reading your last post - with the gearbox showing no other faults, and operating exactly as it should, I am still inclined to believe that overfilling is the cause of your problems.
When many of the forum contributors on here change atf and filter in the 722.6 box, they save and measure the old fluid, and then replace the same volume with new. This gives an excellent datum, and minor fluid additions can then be made if needed with confidence.
Your Indie should have measured the quantity of fluid that he put in. If so, he will tell you how much went in. If he just filled using the dipstick as a guide, this may also be a pointer to your problem.
ajlsl600
france
interesting. so how much do you put in pre start . as cant be good to have it running after draining with little/no oil in ? or are we working on the basis that not all the oil was extracted in the first place, just wondering ,and what a ballache they have made of this process.
Sump drain
Filter replacement
Back together
Put 3.8l in
Start engine
Check level at 80
5 speed :)
No, the a classes are different. They have a different type. (722.1)
moj91
moj91
Northamptonshire
Sump drain
Filter replacement
Back together
Put 3.8l in
Start engine
Check level at 80
Same process as the garage took initially, and the same process as we undertook on refill...
My thought is that if the gearbox was overfilled, would it not just 'blow out' the overfill (roughly) and then sit high on the dipstick? After the car was driven (and fluid expelled) there was nothing on the dipstick. Adding 100ml increments just caused the same again.
The car is currently with Midland Automatic Gearboxes (who rebuilt our W220 722.6), as taken there by the indie - waiting now to hear back from them. If there is a fault hopefully it is not within the gearset (with the gearbox seemingly operating fine otherwise i'm still hoping not - their costs for a 'full rebuild' are more than the car is currently worth.)
The problem with overfilling is that it churns up the fluid, introducing air, which expands the fluid until it blows out.
If it does this it will then end up lower than it should.
I can only imagine a blocked cooler or line could chase the fault potentially but I haven't seen this first hand.
moj91
moj91
Northamptonshire
  • #17
I had been reading about the airation, however it doesn't explain how it took around 700 miles before it started to blow out.
I'll wait and see what midland come back with and go from there I guess... following the procedure above, filling with 100ml increments shouldnt cause that to happen though should it? especially when warm already too...
Any update buddy ?
moj91
moj91
Northamptonshire
  • #20
Thought id give it a week after having the car back before coming back to answer.
So the car was with midland automatic for a while, they checked the box over and seemed to think it was fine.
They put the oil spilling down to an overfill, drained, refilled to what they calculated to be correct.
Got the car back, no issues driving back to the office/home (40 miles). Following day a fair bit of smoke was coming from under the car, but no dripping oil. Decided to just leave it be for a while, i've had a little smoke again a couple of times, but no noticeable dripping. The car is having its MOT on Weds, i will ask the garage to see if the undertray seems wet from fresh oil spill.
Conclusion to jump to is that it was overfilled on oil change - but that doesn't explain how i drove 700 miles before an issue arose after the initial oil change. (Smoke)
We/I definitely added some more oil as according to the Lazer dipstick, it was too low, before driving over to the garage (and then on to Midland) This could be the cause of the 'overfill' as seen by them, and a questionable 'hot' reading from the Lazer dipsticks which both I and the indie don't trust to be accurate/sitting correctly in the dipstick tube.
Continuing to monitor...
Tel: 020 8863 9233
