722.6 conductor plate changed, now won't select any gears.
bully
Guildford
R230 SL350 2006, W208 320CLK, W124 230CE, W201 190E
Anyone seen this before? Local garage changed the conductor plate on my 2006 SL350 after it started sticking in 3rd when in 'sports' mode. Has 51k on the clock and had an ATF oil change 350 miles ago. The sticking started before the oil change. On putting everything back together the car won't select any gear although there is a slight rev drop when gears are selected it's just not 'biting'. Any ideas anyone?
Oldspanners
Normandy
C CLASS 2004 C180
As above or plug not fully in pilot bushing, a bent pin in the socket, oil level incorrect.
What was the oil like when it was changed, did it smell burnt?
Oh and was the plate a MB part or non OE?
I take it they aren’t an MB independent garage ?
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
Did they change the pilot bushing too? Most possible causes have been covered, I think it is incorrect oil level. Was filled and checked at the correct temp? Any fault codes?
star
Reading
Smart + others :)
POSs not fitted valve chest correctly, or put the solenoid valves in wrong place or not aligned selector on valve chest with lever.
bully
bully
Guildford
Thanks for all the suggestions guys. Will let you know how things develop.
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
I'd trailer that down the A3 to PCS in Horndean and let Olly fix it.
The original mechanic has made some kind of expensive mistake putting it back together. I wouldn't be using him again.
star
Reading
Smart + others :)
If it was sticking in gear prior to the oil change, did you have a diagnosis carried out? As it seems you have paid to have the oil done twice now.
bully
bully
Guildford
Only happened once prior to the ATF changed and then it happened again a week after the change with an 0715 code thrown up. A bit of research later I understood adapter plug and conductor plate potential issues. Low oil level caused yesterday's non selection problem she's back on the road now and all well so far. Is the float on the conductor plate only there to trigger an 'ATF too high' alert? There was no Engine Management Light or OBD11 code thrown up by the low level ATF.
star
Reading
Smart + others :)
No level light or warning for gearbox, star might have shown slipping gears tho.
Botus
S500/2010/500
they rang you up and said its all gone wrong..... then later discover they didn't put enough oil in... that does not compute - animals out of their depth
not sure how u can fix for a sensible price, but I want it taken out and put back in by someone competent
Doug1234
Bedfordshire uk
OM642 Jeep Grand Cherokee
I always thought the float was there to stop oil foaming ?
bully
bully
Guildford
Update for anyone having the same issues I had. The car's now at 51 500 miles (400 miles on) since having the conductor plate replaced and no issues at all. Having gone through replacing the adapter plus first to no avail and then the conductor plate my advice to anyone with a sticking gear issue and inability to change gear mode selector from Comfort to Sport would be get them both done at the same time to save on costs. Kits are freely available and replacement is about and hour and a half's worth of labour plus ATF costs. Well worth a punt before trying anything more drastic on your gearbox.
rifiki
Worksop
CLK W209 W121190B
Had similar problem, not changing gear etc. Indie in Mansfield replaced the electroplate for around £450/500 since been OK and that was 7 years ago.
WonkyWombat
W204 C250 SPORT CDI 2011
Which indie was this mate?
rifiki
Worksop
CLK W209 W121190B
Benz Service Centre Mathew Rigby 01623239893. 07845680068
