Oldspanners
- Oct 30, 2017
- Location
- Normandy
- C CLASS 2004 C180
That's for engine oil when the manufacturer has specifically designed one.Don't agree with what's been said above.
How often have you come across an engine oil dipstick that has a few inches left floating at the top when you've inserted it?
Dipsticks made for engine oil level checking are all designed to read correctly when inserted to a predetermined stop. - ie. fully home. That's the only certain and foolproof way of measuring the correct level.
No autobox dipstick (sorry Rodders) that when inserted into the tube has a bit left dangling out at the top can be as certain as one of the correct length that sits 'home' when inserted. There will always be a degree of user variation and uncertainty if the dipstick does not go right 'home'.
With MB "sealed for life" transmissions that was never the case and a way was found to stop the dipstick at the bottom not the top to allow for different lengths of guide tube. When you have the sump off to do a filter change put the dip stick in and you will see where it stops.
