Jim2
- Jan 18, 2018
- 1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI 3rd Merc 2018 E class W213
Hi all, a few questions for anyone who has already carried out an oil change on the 722.9 Transmission. The car in question is 214 MB E class 220, W212 with the 722.9
Transmission.
In the BEVO List , there are two MB approved specs listed for the 722.9 trans, 236.14 and 236.15.
236.14 0 Automatic transmission fluids (ATF, CVT) ( CVT= older transmission's?? , using Red Fluid? )
236.15 0 Automatic transmission fluids (ATF, Transfer/automatic)
I'll presume that the 236.15 is the correct spec fluid to use? As in "Factory Approved Mercedes-Benz MB 236.15 fluid spec. Used in special 7G-tronic with ECO stop-start (NAG2FE+) transmissions."
Does this description match the car mentioned above? It does have ECO stop-start, but how will be able to tell if it is NAG2FE?? And this fluid is Blue in color?
Some of the kits I see advertised also show a drain plug for the TC, but I presume ( again) that this plug would apply to much older model's? If so, then is it possible to change the oil in the TC and pipes using the same method as in the 722.6 Transmission's? IE: via the return pipe from the radiator back to the trans?
Any particular problems I should look out for? or any tip's?
Thanks for your help.
Transmission.
