Jim2
- Jan 18, 2018
- 1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI
- Thread Starter
- Thread starter
- #21
I think the pump maintains fluid pressure when the engine is off in a stop/start situation.
The pump is quite small -- maybe 4 inches X 3 inches.
It has to be removed to gain access to the TC drain bolt.
Here is a photo of the pump:-
This is the view you will see from under the car.
And this is the pump viewed from the side that connects to the gearbox.
Note the 2 black pipes. They are identical so it doesn't matter if they get mixed up.
They can come away with the pump or stay connected to the gearbox or else fall into the old ATF drain pan.
Make sure they are in-situ when you are refitting the pump.
Yes, Steve, as they say " One pic is worth 1'000 word's " I'd say that you are right about the Stop / Start function of the pump. That will simplify matter's, for sure if the TC has a drain plug., and reduce costs as well. Now I've sent an Email to Mercedes & Smart asking them if the kit ( the one that you posted) is suitable for my EcoStop /Start Merc, and maybe they will provide an explanation as to what and why there are stop/ start and non stop /start kits. Because,as far as I can see, all the MB part Nrs are the same. So maybe something to do with the Pump in your Pics? I'd hate to get it wrong and face catastrophic destruction later on, it being something as important as oil and filter related.
Thanks again Steve, It's appreciated.
BTW, I've attached a pic of the two different sumps used in the 722.9 transmissions. Might be useful for you or anyone else on the Forum who is thinking about a trans ATF change.
