osc
- May 25, 2009
- 1971 450SL; 1989 911 3.2 Carrera Targa; 1999 BMW 728i
Hi - That hose goes to the radiator expansion tank onto the little pipe just below the filler cap. (I am waiting for hysterical laughter at this point, but I don't know - is it definately vacuum??) There is no sign of a transistorised ignition unit as I've see on later cars. There are wires coming from the loom towards the coil/ballast resistors - red/black and green/black. There is another wire (purple/red) from the starter 'block' near the battery which I assume is the 12V feed direct to the coil which is live when the engine is cranked. There is another green/black wire going from the coil -ve to the points.
It looks to me that the car does not have electronic ignition....Is this possible please?
i was joking when i said the water washers but maybe i wasn't that far off!!!
ok, i think we have a problem here......can you follow the pipe to the back of the engine bay at tell me where it is connected? if it goes into the inlet manifold it can connect in 2 points. one is a horizontal connection straight down on the inlet manifold that you can clearly see if you get you head back there and the other is tucked in horizontally (use a mirrror and a torch)
both are to the right hand side of where the fuel pressure sensor is mounted and this looks like where the pipe is coming from.
if it is on one of these manifold pressure points then the other end of this MUST go onto the manifold pressure sensor.
The little pipe on the expansion tank is an overflow and there should be a open pipe connected here which will drip any overflow down to a safe place and not squirt in your face. Someone who does not know what they are doing has seriously messed about with your car....
Regarding the transistorised ignition unit. It sounds to me like someone has removed this and as far am i know, your car will not start without it. The Other wires you have mentioned are all correct and the same as mine, but as far as I know you need this unit - are there signs of 4 screw holes and a large hole for the wires to come into the engine bay through the wing? I have a spare unit but it sound like there are a few fundamental issues that need to be sorted before you get to this point.
