Hi, regards to all and Merry Christmas. Santa brought an'86 420 SEL, a solid car with 143K miles, which I have known since new. I am changing out the injectors and seals, and could use advice from a knowledgable and experienced person. I bought injectors (Bosch), seals, and green o-rings, I assume the o-rings go under the injector holders. Is it necessary/advisable to remove the black holders, or just change out the injectors? If I need to remove the holder, how? and how much should I worry about the grit surrounding the outside of the holder? I blew off around them with an air hose, but wasn't satisfied with the cleanliness, so I decided to change the injectors and seals, unless otherwise advised.
Engine has high idle speed (1500 RPM), and I assumed it could be the idle control, but decided to change the injectors and seals, as they probably haven't been changed in a while, anyway. incidentally, the injector clamp on the right-front cylinder is difficult to access because of the throttle linkage bracket; will it hurt anything to loosen the two bracket bolts, which appear to hold the intake as well?
One might surmise that I am a beginner at Mercedes, though not at car repair in general. It's like doctoring on one's mother. :lol:
