spiffy
Hey hows it going everyone...I really need your help...long story short I have a E420 i recently got and I put a motor in it, the car runs fine but only on idle does it miss and shake...the engine wiring harness in it was brittle and cracked and some wires were touching each other so I replaced it but now its still missing at idle, it also misses right when you take off like about 1k to 1.5k but anything after that the car runs perfectly fine...i changed the spark plugs and distributor caps and the ignition rotors and it still does the same thing...any ideas on what i should do next?
If it helps for some reason when I remove one of the spark plug wires the engine smoothens out? It should do the opposite but for some reason it gets better...
any ideas would be appreciated
thanks in advance
thanks in advance
