A 160 convoluted belt replacement
RSavage
Sorry if this has been covered elsewhere and also if I used the wrong name in the subject.
Brother-in-law has an S reg A-160. Apparently the belt which drives the alternator, waterpump, PAS, aircon and goodness knows what else has snapped. He has obtained a replacement and persuaded me to fit it tomorrow.
I'm afraid my expertise lies more with Range Rovers and motorbikes rather than Mercedes so am hoping that someone can point out any pitfalls, tricks or even simply how to do the replacement!
TIA
Richard
mattkh
England
A160 W168 1999 1.6
Thanks!
I'll try to give some sort of feedback
Richard
Good luck Richard.
On a different note, has the A class sometimes smelt of petrol inside the car.
R
RSavage
Good luck Richard.
I'm afraid that I have no idea - it's my brother-in-law's car. I will try to remeber to ask him.
Regarding the belt - well that was not a success as it hadn't snapped but had come off the rollers because the lowest idler roller - between the a/c compressor and alternator had decided to commit suicide by melting. The centre roller bearing is solid and presumably the belt tension is high enough to break the bond between the nylon(?) roller and the bearing.
Anyway, B-I-L is in the process of trying to order a replacement roller
Incidentally, does anyone know if resetting the tensioning roller is any more complicated than slackening it and then re-tightening it? Albert Rowe's page, although pretty comprehensive, does rather gloos over the actual re-setting. I have seen instructions, admittedly for toothed cambelts, which involved using three-pronged belt tension gauges. I presume that doesn't apply here but would prefer it to be confirmed by someone who knows!
Cheers
Richard
Oh and the a/c on the 160 seems to be leaking - drips of oily, yellow-ish fluid from the o/s end of the radiator cluster. It doen't taste like anti-freeze or brake fluid so I'm assuming a/c lubricant. Any thoughts?
R
type49
The tensioner is a pre set sprung loaded so it will set itself.
mattkh
England
A160 W168 1999 1.6
R
Is it possible to put a picture of the area.
type49
R
It sounds like AC leak detector fluid which would now be contaminated with R134a gas - you don't want to be putting that in your mouth :shock: :shock:
The area you descride is the reciever drier but there are also 2 x O ring seals for the condensor on that side, so it may just be one of those.
R
RSavage
My conclusion too. I did only taste, not swallow - honest:-? Don't forget I'm really a Range Rover bloke.
Pictures of the leaky area are difficult as the A160 is in Essex and I am in Kent. If I get dragged over there again I will try to obtain pics. I suspect that B-I-L will be replacing it soon as he has gained a second child.
Thanks for everyone's help and advice.
A friendly forum
Rgds
Richard
