A/C Check W203 C220 CDI A Coupe 2003
DMK/Happy
SE / Coupe / 2003 / C 220/CDI/A
Hi! how much does it cost to have the A/C checked and refilled and how long does it take normally?
bertb1
C220 amp sport 2013
Around £60/£80 and it takes around an hour
DMK/Happy
DMK/Happy
The red pilot light is showing on the A/C button continuously,looking like she needs new refill and checkup,much appreciated.Thank you. ....
David Richardson
Plymouth
W176 Blue Eff CY Sport CDI & C Class Coupe 2002 220CDI
I think that you'll find that the red light should be constantly illuminated when the air con is switched on & is not an indication of any fault
DMK/Happy
DMK/Happy
Interesting comment,other mbo threads on here explained a/c button red pilot light on indicated a/c stopped on this W203 c220 CDI A model year 2003.Thanks
Mercedes used to be red light on equals AC off, they changed it to red light off equals AC off same as everyone else. Early 2000’s was the change over IIRC
DMK/Happy
DMK/Happy
Im blowing cool but not cold air,went through all the settings,Red light on when pressed increases fan blow function,does not blow cold? Red light pilot stays on when ignition switched... Confirmed ON all the time !!
