B
brick10
Hope you get it sorted.
Glad you got sorted but drilling a hole in the tank???! Then sealed with 2 pac chewing gum?
Well -- It looks like I now have the same problem -- most of the time my music is way louder than the sound back there -- but there is something definitely rattling around in there.
What solutions are there? £400 seems like a lot of cash for a mystery solution. And a fuel tank replacement seems a little extravagant.
If you can contact Jameson1 on here, he did ours and as I said it has lasted 18,000mls so far.
He was last on in January so not sure if he is still around, but worth a try. He was in Suffolk.
Unfortunately I don't have his number anymore as it was lost when my phone failed.
This fix has been around a while and someone I know also had it done. Apparently all you need is a piece of rod with a hook on it. The holes drilled are in the loose baffle and the tank sender unit. You then attach the baffle to the tank sender. Or so the principal goes. No actual drilling of the tank. I found a document in German on the net which I have had translated into english and that how it is explained.
Can anybody offer me a guaranteed solution that's proven and effective?
