Right.... All you "rusty" dipstickers! Some photos...
1. The inside of my timing cover - the breather and conection are just to the right.... THIS is the colour of your dipstick if you have a faulty breather...
2. A shot of the inside of MY sump.... That black stuff is rubber crumbs....
3. A shot of the inside of the 2nd hand sump <50,000km .... That black stuff is also rubber crumbs....
4. The breather hose (both engines the same!) 'puking' black rubber crumbs...
5. The breather hose cut lengthwise - note how perished it is.....
6. The inlet that blocks from all the crumbs of rubber (both engines were totally blocked). You can just see the hole at the back of the inlet connection on the manifold...
So..... Any "rusty dipsticks" out there??? If your dipstick is this colour then your breather system will definately be blocked, causing accelerated contamination of your oil because the blow by gases are not being drawn out of the sump. Your oil will be black and smelly and your engine may soon start sounding noisier as your hydraulic tappets start to malfunction.....
