A160 Issues
Jninmps
A160 2005
Hi everyone
New to the Mercedes and I recently bought a A160 with the ACS gearbox.
I am experiencing a few issues
1. Under sudden hard push of the throttle the car looks like it slips revs up and nothing happens.
If I accelerate slowly there are no issues except on the 5th gear.
2. The heater/air con blows air when the car is moving. How can I check the flaps if they are close properly?
3. I filled the car with petrol and the gauge was showing full tank. I turned it off went home and after 2 hours I started up and the gauge is stuck on 0. When I switch off the car the gauge disappears as per normal
any suggestions guys?
Would be much appreciated...
mattkh
England
A160 W168 1999 1.6
What is an ACS gearbox, please explain.
mattkh
England
A160 W168 1999 1.6
thought they only had full auto or CVT myself ??
They did have a Semi-Automatic which is a very confusing name. It is a manual gearbox BUT no need to press the clutch pedal when changing gears.
J
Jninmps
A160 2005
Yes exactly that gearbox. No clutch. The acs module does the pressing of the clutch. All you do is to change the gears. acs is the module.
Apologies for the confusion guys
J
Jninmps
A160 2005
same as a fiat grande punto then
I think so
mattkh
England
A160 W168 1999 1.6
I think so
In that case, the problem with the 5th gear......
Normally, this is because the gearbox oil is LOW. So I would suggest a top up of the gearbox.
J
Jninmps
A160 2005
Thanks I will do that although I am not sure how the low oil will affect slipping. It happens on the 4th and 3rd as well only though if I press the accelerator hard
mattkh
England
A160 W168 1999 1.6
If the mileage is above 90000, then it might be a slipping clutch.
Confirm it by doing a hill test.
J
Jninmps
A160 2005
It has 170k kms.
1,2 gears are good. I haven’t redline it though.
Will I have to replace the flywheel too?
mattkh
England
A160 W168 1999 1.6
Thanks so it’s definitely the clutch? Not the acs module that does not disengage the clutch fully?
If there is no crunching noise when changing gears, then it is not the module.
J
Jninmps
A160 2005
Thanks guys
I believe I have to bite the bullet on this one and replace the clutch
How about the fuel gauge?
J
Jninmps
A160 2005
I fiddled with the plug at the back by unplugging it with the ignition on, turn it off and then plug it back on and it was able to show me the correct reading on the fuel gauge for a few seconds. After that it goes back to 0. I also unplugged the battery and now I have check engine light on.
Lol any suggestions?
