maldini40
- Jul 3, 2023
- A180 Blue Efficiency SE CDI
Hi All, I have a A180 2014 diesel which only blows ambient air inside the car. Had it on and OBD with a garage and it came up with Evaporator Temp sensor fault (open circuit). Have replaced that now (with this) but it hasn't made any difference. Have checked all fuses, non blown. Near where the temp sensor the two large metal pipes which go into the blower unit?? are hot, so it seems heat is getting into the cabin. Doesn't matter if A/C is on or not, just cool air coming from the vents. The blower is working, blowing at a decent rate through all the speeds. Could it be a fault with the heating controller itself? Any ideas/thoughts. Really am desperate now! Thanks in advance.
