A40 - No Gear Selector indicator on Dashboard
2005ak
Hi all,
First thread so appreciate the help - A140 2001 Fully Auto 47K miles.
Driving home last night and noticed BAS/ESP light followed by engine light and car not doing more than 25 mph - so must be in limp mode.
Changing from P to R to D causes a mighty thud.
Funny thing (well not when it burns a hole in my pocket) was that 'Gear Selector' display on the dashboard went missing and nothing is shown.
Called AA this morning who did some checks but nothing conclusive.
Followed up be calling a Merc Specialist who initially indicated could just be an ABS sensor.
When he did a full diagnostic check it seemed that unable to communicate with Gearbox ECU and thus diagnostic cannot report further on that.
Nice chap who took a lot of time, jacked up car and based on his kit maybe dodgy or loose wire connection with the Gearbox ECU - although he was unable to pull apart so still TBA.
Fault codes amongst other were P1875-000, 001, 002.
CAN Communication is faulty, fault with control unit A1, and with control unit N47 ESP module).
Following sounds bad - Fault in CAN communication with control unit FTC and TAC.
I have read that a recent thread that new gearbox ECU from MB means new GB and thats 3000 squids.
Been told that can fit a g/b ECU independently for about 1200 - but still hurts.
Any previous experience / ideas / help / comments.
Thanks in advance.
A
andy@pcd-ltd
It really needs to go on a star machine to be diagnosed fully.
If you say you have no gear display on the dash it could actually be the selector module that has failed causing it to bang into gear
2005ak
Thanks Willow132.
Had two diagnostic done now - and the second garage indicates that I get a Auto Electrical specialist to check out the electrics on the car - does make sense in a way.
Another thing I noticed now was that every time I start the car the clock resets to 0:00 - as though the car is being reset every time I start it.
With the garage now and fingers crossed !!
A
andy@pcd-ltd
Yeah sort of makes sense. Does this garage have a star machine to check it with as i have used a couple of diagnostic machines and machines other than the star can somethimes miss of fault codes and problems.
Keep us posted
miknik
Berkshire
www.mercanix.co.uk
Vito 111CDI LWB
Selector module failure on A class normally results in F being displayed on dash. No display at all is usually g/box control unit.
hellgrace5
Sorry to bring this old thread up.
The thread starter and I had the same problem. Car suddenly went no power and no gear indicator on instrument. Fault stored P1875 and P0600.
A large "bang!" occur when going from P to R and to D.
Mine was a A160 W168 Fully auto trans.
Any idea ? Or just the floor shift module and the tranny is acting up ?
Cole@MBS
www.mbssouthampton.co.uk
It could be anything from a rpm sensor to the floor shift to a valve body in the box, As Willow says above, it needs to go on to star, guessing otherwise!
hellgrace5
I dont have a Star here and there is no authorized Mercedes dealer here.
Maybe you can help me by identifying what the P0600 & P1875 is ?
I've tried sourcing for a Star but no help here at Papua New Guinea.
hellgrace5
@update
I am at the same situation with 2005ak which I cant get reading into the FTC too.
timanfaya43
england
a class 210 auto
hi.did you get this problem fixed as i have exactly the same fault.
hellgrace5
I have not fix it yet but I have ordered a auto trans and new floor shift. Will update here asap i fix it.
lucyyomi
Kent
A Class
All the info on A140 and gears is worrying! I have a 1999 A140 semi-auto. The gear selector screen does not light up another more. The gears have now stopped working! If I look closely at the indicator, I can faintly see F displayed on the gear selector...Please help! am I going to have to go cap in hand to the bank mgr?!
Alex Crow
Super Suffolk
might be a cheap fix - often just brushes in the ACS control unit fixes it. bang on the top of the passenger side front wing to see if it fixes it temporarily.
ELGRINGO
fylde coast
e230 c180 sl280 brabus a190 smar cart
As above repaired many wiyh new brushes.
