abs/esp fault
Alldis
Perth Australia
ML320 /2000/?
ML 320 2000:
Just had a fault diagnosis done by the RAC as having intermitent trouble with shudder noise when braking.
Diagnosis comments were:
Tested no grindin noise found when breaking. Inspected F & R Brakes. Pads F&R approx 35% worn. F/dish 26mm/min23mm R/Dish 14.7mm/min13mm
Can hear noise & feel through brake pedal as if ABS operating. Suspect ABS/ESP fault.
No warning light on dash.
Scanned system for codes
Fault code C1025 can cignals ABS not available.
Further investigation reg.
*RF outer cv ? cannot read Leaking onto hub. New Rod(this means I have a new rod as had new rod and crank shaft thinggy recently)
* cleaned memory/Road test & noise not heard. Montior reg.
So my question is what should I do from here, and should I have any undue worries re this.?:confused:
jibcl500
Cambridgeshire
CL500,ML55,SLK280
needs star diagnostics first nd then go from there but suspect ABS pump wiring at fault.
jib
I cannot follow this, no warning lamps on but you have the 1025 fault code, was that cleared and still current
