M
mkinspain
Having the ABS & BAS dash lights up for some time, I have been informed, after diagnostics that the ABS pump requires replacing, part number A 002 431 92 12. As this is an expensive item, is it something I could change over myself as I am not too bad with the spanners, however not sure about the fluid part of the operation. I hope someone can advise if you think this is the answer to the problem and if the change over is easy enough to do. Many thanks
