renrutp76
- Mar 27, 2012
- Location
- Chester
- X218/2014/CLS250CDI_W211/2005/E500 Avantgarde
Following a lot of recent work, I have a very frustrating fault..... My 2005 E500 has not been driven for a couple of years, and after charging the battery and taking for a short test drive there were more problems than I could have imagined which are covered in another thread. A couple remain, but I will post in the relevant sections. I currently have error 4636 (current and stored) right rear speed sensor, which activates the ABS ESP faults. I replaced the sensor, and checked the live values while spinning the wheel, and the value changes. I have reset the fault numerous times, but it reappears each time i drive the car. I am currently unable to drive at the moment to test further as my gearbox conductor plate is away for repair. I have also just replaced the discs and pad, not sure if that is relevant (it did mention worn discs in one of the fault causes. when I was looking through the live values the steering angle sensor had a value of 18, with an acceptable range of -2.5 to 2.5 although the next value in the list said steering angle sensor "OK".
has anyone else experienced this issue?
