Suelacy
- Apr 17, 2021
- C200 Diesel Automatic 2017
Can anybody help me please.
My car only has only done 11,000 miles, but a MB specialist says the engine looks like it has done 150,000 miles!!
It all started with an error code saying the NOX sensor had a fault.
After replacing the first NOX further errors kept occurring.
The latest error says "The flow in the EGR (cylinder bank 1) is too low. There is a general failure.
After spending £1500.00 so far and now having the latest error I am at my wits end .
The faults found and work carried out so far have been:
Replaced down stream NOX sensor as per fault code and carried out software update.
Replaced upstream NOX sensor as per fault.
Fault for low pressure EGR valve.
Carried out testes, replaced low pressure EGR valve, noted heavy contamination.
Test low and high pressure EGR systems, all operational, air mass sensor low at idle.
Check air mass sensor, heavily fouled with engine oil.
Excess oil noted in inlet track, check breathers – ok.
DPF heavily fouled, carried out regeneration of DPF, air mass now ok.
Excess oil and carbonation in inlet and EGR systems.
Excess crankcase pressure in engine.
Heavy fouling in breather system.
Requires engine investigation, suspect piston ring/bore fault.
Does anybody know what on earth is happening to my car? The main dealer want £174.00 to read the error code before they will investigate further. I can see this costing me another £2k if they just keep om replacing parts. Surely both NOX and EGRs have not needed replacing
Any ideas / advice would be greatly appreciated.
Many thanks, Sue
Many thanks, Sue
