MarkFL
- Oct 3, 2022
- Location
- Worcester UK
- 2012 S350 Bluetech
I’m still getting Adblue check messages each time I drive 100+ miles but still no codes, and messages/eml seem to clear themselves between drives. Today I decided to clean the metering valve and boy did it need it! (See pics). I’ve run another ‘adaptation’ and a metering valve ‘teach-in’ but the active test of the metering valve always fails to run with a ‘temperature must be above 5C’ message even when it is a few degrees higher, so maybe there is a temperature sensor error. Who knows.............Adblue in my 2011 S350 (W221 50,000 miles), ran low a week ago with amber eml coming on too. Filled up with 20l and anti crystal additive; eml went off but returned after 100 miles approx with another low adblue warning and 494 miles range warning. Checked the level today with a wood rod and it remains full so I gave it a half-hearted stir and refitted filler cap; eml off again and no fault messages. I've connected a YOUCANIC diagnostic device and found a few points of interest:
1/ no stored codes
2/ pump test not possible with temp below 5C
3/ adblue heaters showing no faults
4/ 'maintenance' function has two steps; first 'refill adblue' then 'erase adaptation values after replacement of adblue'
I ran the 'erase' function and I'm hoping that's it.
There are three fill level sensors called 'EMPTY', 'RESERVE', and 'FULL' from which i would infer that only a complete refill will eliminate a reserve level warning. My sensors now have the status WET, WET, WET
