advice on crankshaft position sensor
slick clk
hi guys
i was wondering if any of you could give me some advice on how to change the cranckshaft sensor on my clk 320 1998. i have some basic mechanical knowledge with cars, is it easy enough to change it myself?
and also where is it located?
any help would be very much appriciated
FELLOW
Crank Shaft Center
The chap from mobilo life did mine in ten minutes in an underground garage in Portsmouth.
Bit like changing the spark plugs or front head lamp bulbs ... if you know what you are doing it doesn't take too long (10 mins for the crank shaft sensor) but does involve some knuckle grazing.
It sits down out of sight behind the engine block at the back and has a cover and a screw to secure.....would suggest taking part to inde. and paying for 15 mins of knuckle grazing.....I think there used to be a link in the technical section with pictures on how to do it...
or even cheaper call mobilo life next time it doesn't start!
