Advice re buying a "tuned" CL500
30 post might just do it
M
MikeKnivett
West Sussex
2008 CL 500
  • #85
Can u explain about not being able to upgrade to full postcode? does the Merc system not accept full uk postcodes at all?
Only on a 2011 car onwards, all 5 digit, its OK enter the 5 digits and the road list will come up just chose what road, enter a number and thats it.
Its 30 post or one month
I have sent you an Email
M
MikeKnivett
West Sussex
2008 CL 500
  • #91
Still can't PM! 32 posts now.
Can I write an email here without using the @?
M
MikeKnivett
West Sussex
2008 CL 500
  • #93
Ok so picked up car tonight. Stunningly impressed. For less than 22k it's an astonishing amount of car. Lovely to cruise round M25 in and when I gave it some pulling away from te Dartford toll it goes well for such a heavy car.
Two questions. Bluetooth. Connected to iPhone but couldn't make calls, just got home and read its only for transferring vCard using Bluetooth. Slightly crap for a 2008 car if that's true. What's the solution as I'm assuming the iPhone won't fit in the connector ?
Secondly is there any way to show fuel economy? Found a million other displays but not that one!
The wooden and leather wheel is stunning but as I expected the steering is v v light. I don't suppose if you adjust suspension to sports mode it stiffens up at all?
Totally delighted with car and actually the wheels I was worried about look really good and not drug dealerish at all.
Thanks for everyone's advice on here that helped me make the decision on this car
To show the actual consumption just press the bottom arrow on left hand wheel button once, push the top button and you get a big digi speedo
Look in the armrest top box, is there a connector there for a phone cradle.
S is a first gear start with stiffer suspension, C is a second gear start with a softer ride.
Have you floored it yet they do shift
M
MikeKnivett
West Sussex
2008 CL 500
  • #95
Yes floored it and v impressed.
Will an iphone connect to that cradle or do I need an adaptor either wired or Bluetooth ?
I am not good with phones,,, I have one in the cradle in the arm rest but they are blue tooth friendly, someone else will advise
M
MikeKnivett
West Sussex
2008 CL 500
  • #97
Also Malcolm is there a different back box you can put on to release a bit more of the engines lovely sound?
M
MikeKnivett
West Sussex
2008 CL 500
  • #98
Ok thanks I'll scour the forum for other threads on phones.
That would defeat all the sound deadening and double glazing
the director
Bristolshire
2010 R 350 Grand Edition; 2015 S 350
Play around with the steering controls the MPG figures etc are there (both from start and from reset).
Regarding the phone, presumably there's a doc connector in the centre arm rest? If so, what I do is run with a cheap Nokia phone in the arm rest and set the iPhone to forward all calls to the Nokia. It's not a perfect solution and only really works for receiving calls but, how many calls do you really really need to make while driving.
My alternative is that I also use one of these: (http://www.ebay.co.uk/itm/All-in-1-...cessories_FM_Transmitters&hash=item43c0667c3c). The iPhone mic works well and the sound comes to the car via the radio.
I don't think the steering adjusts though based upon suspension settings - well, if it does I don't notice it.
