w204benz
- Sep 9, 2022
- 2012 C200CDI AMG Sport
Some time ago I had a small diesel leak from the injector return line connectors, which my mechanic fixed by replacing the o-rings and I think the connectors too. I figured everything was fine as I could finally draw fresh air in through the A/C without any nasty smells.
A few days ago, it was pointed out to me that the bubbling noises from the fuel pump while it's priming are not normal. A bit of looking around online and it seems the issue most likely stems from the return line (probably drawing in air). And sure enough, I found there is still diesel around the injectors! So I've decided to just replace the line (A 651 070 24 32).
Normally I'd go OEM, but the dealer quoted a ridiculous price for what is essentially a foot of fuel hose and a few connectors. Aftermarket is much more reasonable, but I'm just a bit unsure about the quality.
I've been looking at a MAXGEAR branded option, the seller claims OE quality (but of course they would). Is anyone familiar with this brand? Any other suggestions would be welcome too.
Or is this something I don't need to be overly concerned about? It is on the low pressure side after all.
