AGM Battery Faulty -
ecoman
W211 2007 3.2CDi
Wanted to share my experience and ask your opinions please
Called out RAC to a flat battery and after charging at roadside for a while was told battery wasn't taking/holding any charge. Now this is a 9 month old Mercedes supplied AGM battery that the RAC tested as faulty. Tried my own battery charger at home and same result, not taking any charge.
Returned the car and battery to MB to be told battery all good- here's the £120 bill for the diagnostic.
Uncle Benz
West Sussex
Mainly Mercedes
What sort of battery charger did you try on it?
E
ecoman
W211 2007 3.2CDi
Not sure what to do with that, but thanks for your replies all the same
SO..... received a call at 2.30pm to say battery was at 7.2v and they needed car overnight to fully charge and then do a discharge test. Protested a little and they agreed to charge battery for 2 hours and see if it held charge. Called back at 4.30pm to say battery fully charged and passed MB test. said printout showed 95AH.
question: should the test not show CCA? also 2 hours seems quick to fully charge a 95Ah battery and perform a discharge test.
AMGeed
Poole, Dorset
S204 C180K
The battery needs to be fully charged (12.6V+) then tested under load (CCA)
If the CCA is well below the stated output the battery needs changing.
Uncle Benz
West Sussex
Mainly Mercedes
Low and slow, just like a boeuf bourguignon. AGM batteries don't respond well to a fast charger. I'm speculating here, but that may have been your problem.
E
ecoman
W211 2007 3.2CDi
thank you for the insights.
My charger is a fully auto charger but I cannot see that it has a specific AGM mode if one is needed - It regulates its voltage between 13.8v and 14.9v depending on the drain.
Given the "low and slow" is it likely to be fully charged after only 2 hours?
Uncle Benz
West Sussex
Mainly Mercedes
If they have a very high tech charger, which tbh is pretty likely, then yes, quite possibly. You'll know in the morning.
That, or they have fitted a new battery and you have paid for it...
Uncle Benz
West Sussex
Mainly Mercedes
Date code will be stamped on one of the terminals. Might give a clue
E
ecoman
W211 2007 3.2CDi
Wait till morning and see if it's fixed...
E
ecoman
W211 2007 3.2CDi
thanks all
Botus
S500/2010/500
wow, didn't occur to me the dealer could be a crook.... you should be able to spot if the battery looks new vs 9 months old, I presume if checked at a main dealer they didn't just stop at testing the battery, what about alternator output?.
when u say issue at the roadside do we mean parked up outside the house or out on a journey?
E
ecoman
W211 2007 3.2CDi
  • #20
TBH my first thought was that they couldn't be........ then after the explanation over the phone about not being able to do anything unless they had it overnight and then 2 hours later all was well and it passed all the tests (including a drain test). The numbers from the test were for AH and not the CCA which I thought the test equipment output as its measure?
It was parked up over the weekend but away from home and without jump leads! Alternator checked out ok (using a spare battery) and the dealership confirmed alternator was fine.
