WoodyBristol
- Thread Starter
- Thread starter
- #21
Our air conditioning regas machine will automatically hold a vacuum in the system for 25 minutes. If no vacuum loss is detected, it will carry on and refill the system. If it does detect a loss of vacuum, it will abort.
Unfortunately often the leak is so small that the vacuum does not drop. We only know when the customer phones back up after a few weeks. We always put a dye in the system, but unless the leak is in a visible area, sometimes you cannot see it with the UV lamp.
The system should then be filled with Nitrogen at a higher pressure to enable finding the leak(s)
If you know that there is a leak, it's illegal to carry out a regas and allow gas to escape into the environment.
Thanks for the info - very interesting. I've requested a refund from Kwik Fit, they are yet to reply. if they don't refund me the information you supplied will come in very handy.
