Air Filter Change
Dunhamkid
Outside Chester
W222 2015 S350 Bluetec
I own a 2015 S class 350d Bluetech. I wish to change the air filters, so I looked on Youtube. One video suggests that once the filters are changed, the car needs to go on Star to "calibrate" the filters. I presume that the sensor that needs to be removed to remove one side of the filters, measures the vacuum in the filter box and adjusts fuelling accordingly?
I would have thought that the sensor would self calibrate once new filters had been fitted?
Thoughts please
onefortheroad
uk.
The car will readjust fuelling once the filters are changed . I'd think the only time star would be needed is when the old filters are absolutely Minging.
Downlands
Margate kent
C220 cdi blue efficiency AMG sport
Thoughts please
My wife just had the same problem on vw polo ! New filter and then had to be recalibrated ecu for air intake and was advised it is the same for MB something to do with position of butterfly inlets and throttle position
Mark A
Aberdeen
58 ML-320CDI.
Haven’t had to do STAR calibration on any of our Merc’s over the years. Even the CLS didn’t need anything.
Downlands
Margate kent
I was advised by MB workshop that he has had this problem on occasion when fitting new air filter the ecu waning light showed on dash and fault code showed air intake ?
Jim2
In both E classes that I've owned, I've changed the airfilters without any problems, but for other MB models it maybe different.
mersum1es
Finland
'Need' and 'can' are different things. Probably very few have reset adaption values after changing MAF...
Both values are adjusted by learning, so usually driver notice nothing. Remember couple of reports when engine started behaving slightly naughty after filter change.
MB doe this a matter of course during service when replacing the air filters. Have this on the receipt from my last service on my W251.
Otherwise the car relearns which takes time.
