Airbag ecu needs replacement eclass a207 60 reg
Sie...1
Eclass conv a207
hi all, srs light & active bonnet & passenger seat airbag switched off warnings all came on dashboard together no crashes etc.. jus had a star programme machine run a test and said internal fault with the airbag ecu/ module together with fault b2207/b2208. Have any of you guys encountered this problem & would you advise buying the replacement ecu/module part off eBay & fitting it yourself or get a specialist would appreciate any advice thanks Sie
Mark A
Aberdeen
58 ML-320CDI.
I would wait for one of the Indies to reply but some of the modules are only able to be coded to a vehicle once - therefore a secondhand unit off eBay may be of no use to you.
I had this problem on the kids old Pug 207. When I had to replace the ECU on my SLK I went for new just to make sure I didn’t have the same problem.
Sie...1
Eclass conv a207
Thanks for the advice mark appreciate it cheers
