Alarm problem
Smacsor
Bristol, UK
2013 C250 CDI AMG Sport Plus; 2011 C220 CDI Blueefficiency 125 Edition - SOLD; R230 SL500 - SOLD
I don't generally use the SL in the week, just weekends.
I went to use it tonight and I had a message on the dash saying "convenience functions temporarily unavailable". I understand from searching the forum that this is due to a low aux battery as the car isn't used for periods of 4 or 5 days and that this is quite common?
However I am also getting a problem that when I lock the car with the remote button on the key, the hazards flash continuously. I think this is the alarm but the sounder has never worked. I have to unlock it and lock it a few times to get the lights to stop flashing.
Is this associated with the low battery, or is it an unrelated issue.
Thanks,
Simon
Smacsor
Smacsor
Bristol, UK
  • #2
Have just seen Andys320's post. Do I assume I need a new siren as well? What should I do if it gets to the stage where I can't stop the lights flashing?
I would have said yes, the siren has water in it
Smacsor
Smacsor
Bristol, UK
Thanks Malc. Is this expensive to have a new one fitted?
Its a DIY and about £80
Smacsor
Smacsor
Bristol, UK
I'm afraid not much is DIY with arthritis in fingers!:mad:
johno2004
SLK32 AMG
Had exactly same problem with my SLK last week and it was the siren cost £85 and all is well now. Takes about 30 mins to fit so Indie wont cost much.
Smacsor
Smacsor
Bristol, UK
I've got a couple of other little electrical gremlins (clock so dim you can't read it and bezel around headlight switch doesn't illuminate) so I'll book it into the local Indy and get it all done at once.
That will be all known problems sorted then (whispered quietly in case car hears and decides to rebel).
The lamp switch does not light up on the 230
Smacsor
Smacsor
Bristol, UK
Just two problems left then :)
Nothing repairable in the cluster, have you tried the dimmer
Smacsor
Smacsor
Bristol, UK
Yes, dimmer is turned up full. It's literally so dim that you can't see the digits in daylight. At night, it's a faint glow but just legible.
Mine are not that bright on my 216 I would have a word with www.actronics.co.uk and see what they say 01206 849920
Smacsor
Smacsor
Bristol, UK
Thanks Malcolm. If its just the siren, I might have a go myself and if I get stuck with my dodgy fingers, I'll have to give my son a shout!
Are there any instructions you can send me, or is so obvious, I can't go wrong (famous last words)?
It should be at the top rear section of the front wheel arch line, I will confirm later
Smacsor
Smacsor
Bristol, UK
This morning I had lots of brake, nav and convenience warnings and the car would only just start. I guess I need to use it more often! Is this both batteries or just the aux that affects all this? Can I safely put either or both on a trickle charge on the car or do I need to remove batteries to do this? If I remove them will this affect codes etc?
Sorry about all the questions but don't want to mess anything up!
Simon
